Greetings,
I am simulating a building with a large number of modules. The installed capacity is 4000 kWp and the simulated production is 9 760 000 kWh/year. This gives a performance ratio of 221,8 %
This performance ratio is clearly not feasible. I have simulated the same project in Solysun and the simulated production is 2 700 000 kWh/year. PR is approximately 85 %.
How do I fix this error to have a more feasible performance ratio for my project?
Best regards,
Hi Martin,
I understand the problem. Thanks for looking into it for me.
I am not sure what value I should input for low light values. The module I was trying to create was the new Jolywood JW-HD144N / 570 W
Can you suggest an appropriate value for this module?
I have attached the sheet for the module.
Best regards,
JW-HD144N-550-575.pdf
