CodrinSomesan Posted March 20, 2023 Report Posted March 20, 2023 Dear community, can someone explain to me what should I do? It is something wrong with my configuration? The simulating never end! Thank You in advance. Codrin Somesan Quote
developer_mh Posted March 21, 2023 Report Posted March 21, 2023 Hi Codrin Somesan, this is a known bug and will be fixed in PV*SOL premium 2023 R4. In the meanwhile you can use the shortcut Ctrl+F5 as workaround. Hope that helps, kind regards, Martin 1 Quote
Kostas Karanasios Posted March 21, 2023 Report Posted March 21, 2023 Hello, I have the same issue and the shortcut Ctrl+F5 is not working either. Could you please help me? Kostas Quote
developer_mh Posted March 22, 2023 Report Posted March 22, 2023 Hi Kostas, which version of PV*SOL premium are you using? Could you send me your project file, please? Here in the forum as private message. Thanks and best regards, Martin Quote
Sara Posted March 23, 2023 Report Posted March 23, 2023 Hi! I have the same problem and the Ctrl+F5 doesn´t work. Where should I send the file to get help fastest? Quote
developer_mh Posted March 23, 2023 Report Posted March 23, 2023 Hi Sara, which version of PV*SOL premium are you using? Could you send me your project file, please? Here in the forum as private message. Thanks and best regards, Martin Quote
Patricia Ruiz Posted April 5, 2023 Report Posted April 5, 2023 Hi! I have the same problem and the Ctrl+F5 doesn´t work. Can you help me please? Quote
developer_mh Posted April 5, 2023 Report Posted April 5, 2023 Hi Patricia, which version of PV*SOL premium are you using? Could you send me your project file, please? Here in the forum as private message. Thanks and best regards, Martin Quote
