soporte de modulos (drag and drop not working in 3D)
Buenas tardes, en el apartado de soportes de modulos, configuro el sistema de montaje y una vez hecho , no puedo arrastrar modulos , antes si me dejaba hacerlo, pero ahora no me deja arrastrar los modulos para colocarlos, alguien me podria decir a que se puede deber?
gracias
Hi Alejo,
here is the translation of your question from deepl.com:
Quote
Good afternoon, in the section of module supports, I configure the mounting system and once done, I can not drag modules, before if I let me do it, but now I can not drag the modules to place them, someone could tell me that it can be due?
thanks
There are several users with Windows 11 that have reported that issue. It might have something to do with a specific Windows Update, but so far we have no idea what exactly is causing the issue. This is really odd. You have a working piece of software, then Windows Update comes and only one particular part of the the software stops working. We have not had that kind of bug before, but we are continuing to investigate it.
In the meantime you can still work with the "Fill Area" tool in order to get the modules on the roof:
  • developer_mh changed the title to soporte de modulos (drag and drop not working in 3D)
