RachelEnergy Posted March 9, 2023 Report Posted March 9, 2023 How do you enter the following information into the schematic title block: Created by Approved by Part number  Thanks Quote
developer_mh Posted March 9, 2023 Report Posted March 9, 2023 Hi RachelEnergy, the field "Created by" is filled with the value of the Project Designer: Â "Approved by" and "Part number" can't be set from within PV*SOL, but only after you exported it. Best regards, Martin Quote
RachelEnergy Posted March 14, 2023 Author Report Posted March 14, 2023 Thanks Martin. Could you explain further what you mean about Approved by and Part number? I can only export as pdf or png, neither of which are easy to edit once exported (unlike a word doc) Quote
developer_mh Posted March 15, 2023 Report Posted March 15, 2023 Hi RachelEnergy, what I meant was that if you export it as an svg, you can edit it with any vector based drawing software. Personally I find inkscape a very good choice, it is free and open source and very powerful. After editing, you can easily save it as pdf for example. Kind regards, Martin  Quote
RachelEnergy Posted March 16, 2023 Author Report Posted March 16, 2023 That's brilliant, thanks Martin. Quote
