Hello
I would like to design a system like a gadjet which doesn't require any inverter. But it is required to choose the inverter in designing process. How can I disable the inverter selection or the AC mains in the first step?
Thank you all.
Hi hazywayrunner,
in PV*SOL you will always have to define some kind of inverter in order to have MPP and voltage conversion functionalities etc. If you are interested in a DC application, you could change the grid voltage to your DC voltage (say 12 or 48 V or the like) and define an inverter that is really behaving like a DC/DC converter then, but with MPP tracking functionality included. But you can't disable the inverters or the AC grid. You just use inverters as DC converters and the AC grid would be your DC grid :)
