Farzad Jafarkazemi Posted April 26, 2018 Report Posted April 26, 2018 Hi, In 2D calculation there is a calculator for optimum tilt which is location dependent. Is there such a calculation available in 3D? It seems that in 3D it should be assumed as known. Regards, Farzad Quote
developer_mh Posted April 30, 2018 Report Posted April 30, 2018 Hi Farzad, you are right, the option to calculate the optimum tilt angle is missing in 3D. We have it on our list, but in the mean while you would have to start a new 2D project, select the location you want to use later in 3D and calculate your optimum tilt angle and write it down somewhere. Then you know it for your 3D planning later. Sorry for the inconvenience, kind regards, Martin Quote
