NEW TARIFFS TABLE
Dears ,
we are in Saudi Arabia and I'm new in PV sol, I need to add tables off tariffs according to this data :
1-6000 watt/hour the cost of the watt is 0.18
from 6000 watts/hour to max the cost of a watt is 0.3
because I didn't  see the option of watt/hour
bashir alqatanani
Hello Bashir,
welcome to our forum.
In PV*SOL you cannot select watt/hour as a unit. Watts/hour is also a pretty strange unit for an energy consumption tariff. Normally you would have "currency per kWh". In a quick search I found your tariff on this website http://gulfbusiness.com/saudi-double-electricity-prices/ There I could find watt/hour, which, as I said, is pretty strange.I looked further into this and found these two websites
http://saudigazette.com.sa/article/524039/SAUDI-ARABIA/Electricity-tariffs-to-be-revised-from-Jan-1
https://www.se.com.sa/en-us/customers/Pages/TariffRates.aspx
On these websites the consumption tariffs are given in halalas per kWh, which would make much more sense.
Finally in PV*SOL you can select "your currency/kWh" for the tariffs. Just go to "Databases -> from-grid tariffs".  There you create a new tariff like this one:
Marcel.
HI developer_mm,
thanks for your helpful answer its help me so much.
About the price of each PV panel & inverter can I insert it to the PV sol ????
