Kamal Posted November 3, 2017 Report Share Posted November 3, 2017 Hello, I'm a bit new with the software and I tried to find the answer of this question before writing this message, without success. Here's the thing, I would like to put a default value for the module degradation. I always put the same value (90% after 20yrs) which I think is consistent with the field behaviour. Is there any possibility to put a default value for this? Thank you for your help and you really did a great job for the software! Quote Link to comment Share on other sites More sharing options...
developer_mh Posted November 6, 2017 Report Share Posted November 6, 2017 Hi Kamal, thanks for your kind words! Unfortunately it is not possible to have standard values for the module degradation other than 100%. What you could do is to define kind of a template project where you set your module degradation to 90% and then preload it every time you start a new project. Kind regards, Martin Quote Link to comment Share on other sites More sharing options...
Kamal Posted November 7, 2017 Author Report Share Posted November 7, 2017 Hi Martin, thanks a lot for the answer, I appreciate it. Your recommendation of creating a template is not feasable for me because the number, type and areas are changing from a project to another. Hence I will have to compute this 90% degradation afterwards anyway. But now it's clear, Best regards Kamal Quote Link to comment Share on other sites More sharing options...
