I am hoping to build a set of irregular buildings based on a design drawing (see attached).
I have outlined each different pitch and extruded as an arbitrary building. The option to deactivate collisions is not available for arbitrary buildings. Is there another way to force the buildings to overlap?
Sometimes when you first pick up a building it allows you to overlap with another building but this seems to be a glitch. This is how I have overlapped the other joining buildings.
Any suggestions on how to get 2 arbitrary buildings to overlap?
Many thanks
James
Hi James,
You have several options. You can simply draw the polygon overlapping and finally extrude the two buildings.
If you use standard buildings with rectangular base area and saddle or hipped roof:
  • you can enlarge the width of the attic,
  • draw the polygon overlapping and extrude, or
  • disable the collision and push the buildings into each other.
Kind regards
Your Technical Support Team
