Florencia Posted June 15, 2017 Report Posted June 15, 2017 There is no suggested configuration for the inverters due to  "configuration limits". What should I put in configuration limits so that the system provides a suggested solution? I am using default setting. The project is in South America. Quote
developer_mh Posted June 16, 2017 Report Posted June 16, 2017 Hi Florencia, if the automatic configuration does not find a suitable combination of your PV modules and the selected inverters, the reason is most likely because the inverters you selected do not have the features that would permit a proper configuration. For example, if you have 10 kWp of PV modules but you only selected inverters with a rated power of 20 kW and above, the automatic configuration is not able to find a good solution for you. Also, if you have more than one module area and you want to connect them to one inverter, but you have only inverters with one MPP tracker in your selection, there will be no configuration possible. Just try to add other inverters to your selection, perhaps choose models with different AC power ratings, voltage ranges and MPP trackers and the like, and try again.  If you need further assistance, please let me know, kind regards, Martin  Quote
