Johan van t Wout Posted March 15, 2017 Report Posted March 15, 2017 Hello, I'run into a little problem with the module configuration module. The roof should be configured into 3 strings of 19 modules. And that is going ok, only the strings are not in one sequence. One string is 18 PV Modules and 1 is located on a different position. Off course thats not what we want. It looks weird in the planning and also it's weird for the cable plan. Can you please help me out how to fix this? Thanks a lot in advance  Regards  Johan  Quote
developer_mh Posted March 15, 2017 Report Posted March 15, 2017 Hi Johan, thanks for your question! You can just drag the orphan module next to your string. In fact, you can drag it anywhere you want. When you begin dragging, a colored frame will appear that you can move over a module of another string. In your case you might want to place it above 7.1.3.14 and left to 7.1.3.1, right? When you drop it there, it will be switched with the module that was there before. Hope that helps, kind regards, Martin 1 Quote
Johan van t Wout Posted March 16, 2017 Author Report Posted March 16, 2017 Yes! That worked out. Thanks a lot Martin! Quote
