Alfredo Posted January 12, 2017 Report Posted January 12, 2017 Hi, Hi I would like to have more clarity with angles that are entered into the tracking systems. Tilt and rotation angles for all tracking options. How to define the limits. thanks for your help  Regards   Quote
developer_mh Posted January 13, 2017 Report Posted January 13, 2017 Hi Alfredo,  thank you for your question. In the new version (2017 R6, will be published in the next weeks) we will have new pictures in order to make the tracking options and angles clearer. The angles are defined as follows:  Single North-South Axis  Rotation axis incline: The rotation axis (marked with little red dotted circle) is located on the north-south plane. 0° would be vertical, 90° horizontal. Rotational angle of opening: If entered 160°, the module can rotate by 80° to each side around the rotation axis.  Single East-West Axis   Rotation axis incline: The rotation axis (marked with little red dotted circle) is located on the east-west plane. 0° would be horizontal, 90° vertical. Rotational angle of opening: If entered 160°, the module can rotate by 80° to each side around the rotation axis.  Single Vertical Rotation Axis   Inclination: The module has a fix inclination angle that you can choose. The rotation axis is vertical. Azimuth angle of opening: If entered 200°, the module can rotate by 100° to each side (east and west) around the rotation axis.  Dual Axis   Maximum Inclination: The maximum angle the module can rotate to. 0° is horizontal, 90° will be vertical. Azimuth angle of opening: If entered 200°, the module can rotate by 100° to each side (east and west).   I hope this helps a little to clarify the different tracking options and their angles.  Kind regards, Martin  Quote
developer_mh Posted July 12, 2018 Report Posted July 12, 2018 Hi everyone, please see our new tracking videos here: Kind regards, Martin Quote
Aneta Posted December 28, 2020 Report Posted December 28, 2020 Hi, where I can find the option "Sun tracking system" in progrma PV Sol? Quote
developer_mh Posted January 4, 2021 Report Posted January 4, 2021 Hi Aneta, you can find the tracking system on the page "PV modules" that is visible if you uncheck the option "Use 3D design" on the page "System Type, Climate and Grid". Hope that helps, kind regards and a good start into 2021, Martin Quote
