August 25, 201610 yr comment_899 Good morning, My name is Esteban. I am user of PVSOl 2016. I am trying to simulate a real fothovoltaic plant. This plant has strings of 20 modules in series, but I couldn´t found the option in PVSOL to configure 20 modules in series, the value maximum possible is 14 modulues in series. I attached some images, the first one is the schema of real plant and the other is my simulation. How can I configure strings of 20 modules in series? Thanks. Best Regards, Esteban Ayala ChavarriaSAWEWA int.esteban.ayala@sawewa.comcel: 3015202695 Report
August 29, 201610 yr comment_903 Dear Esteban, the solution to your problem lies in the inverter you have chosen. The new model by RefsuSOL Inc has a smaller voltage range than the older model distributed by REFU Elektronik GmbH. When you choose the older model, you can connect the modules as you would expect. See the screenshot: Also, I attached a project that corresponds to the schematics of the older version of PV*SOL that you provided. Kind regards, Martin RefuSol 4x20 Phono PS250P20U.pvprj Report
August 29, 201610 yr Author comment_905 Dear Martin, Thanks so much for your help. Best regards. Esteban Report
