Hello,
At the moment I'm simulating a plant which has quite a bit of inverter down regulation on account of max. AC power/ cos phi. This is due to the sizingfactor of the inverters being quite high. But is it also possible to run the simulation over multiple years. My expectation is that the down regulation would be less each year (at the same solar irradiaton) due to the degradation of the modules.
Is this possible to simulate this, so I can have some numbers by my expactation.
Thanks,
Hi Jan K
For having calculated values, you must simulate several projects having different degradation values from the beginning I'm afraid.
Kind regards
