February 2, 20233 yr comment_9768 Hello, i haved used drone to make 3D model of building. All is good but after import the .obj file into pvsol my problem looks like on the photo; The building is crooked, i dont know what to do.. Help Report
February 3, 20233 yr comment_9776 Dear liszo, the tilt of the model should be corrected in the software that you use to create the obj file. In PV*SOL, you can only flip or rotate imported 3D models by 90°. Hope that helps, kind regards, Martin Report
