Hello,
My name is Esteban. I have PvSol 2016. I need to know how I can see some information about the different load profile like, the area(m2), the anual energy consumption(kWh/año). In the moment, I only can see monthly energy consumption in percentages(But I dont see the consumption figures).
Thanks. Regards.
Hi Esteban,
there are several options for load profiles. The dialog you sent a picture of enables you to define a load profile for every month and every hour of the day separately in percent (!), which you can then scale to the desired annual energy consumption in kWh
The load profiles that you can enter there are not dependent on temperature or area of the building. If you want wo have real simulations of heat flows in buildings thermal system, I'd recommend using T*SOL, our solution for solar thermal systems, or GeoT*SOL, which helps to simulate heat pumps.
