January 19, 20233 yr comment_9633 How can I draw or define and extrude light domes on top of a building with PV*sol? Report
January 20, 20233 yr comment_9640 Dear Orakel952, if the light domes do not have to be round, you can just use the extrusion tool: In your case you would extrude the whole ridge at once, in two segments, I guess. Then you can also add an inclination like so: I made two extrusion (but didn't move them close together so that we see more detail): Hope that helps, kind regards, Martin Report
