PV panels cannot be placed on roof's structure on new version
  • 2 weeks later...
Hi Venco Gary,
the reason why the top of the object is not selectable is that is a fireproof wall object. The intended use is just for small walls. Try to use an extrusion object, that will work. You can use the polygon tool for drawing the outline of the object and then right click -> Extrude.
  • 2 weeks later...
