Hello everyone,
I have a question regarding the replacement of modules that are already mounted. I know that in the "Administration of Reference Modules"  there is the option to "Replace" but my question is: Can I replace modules that are already mounted and configured with other modules with different dimensions? The bold part of the question is the most important to me, because i would like to know if there is an automatic way to replace these modules without having to do so manually. I assume that it isnt possible, because that would also mean changing the placement of said modules and possbily the ammount. Am I right in this assessment?
Thank you for your attention.
Kind Regards,
Zelev
Hi Zelev,
I assume you are talking about replacing modules within an Assembly System in the 3D environment? This, unfortunately, is not possible since one assembly system can only consist of equal modules.
  • Thanks 1
