Zhaoyu Posted November 4, 2022 Report Posted November 4, 2022 Hi , I would like to know the AC output of the system,but the values could not be found in the simulation hourly values results(excel file). What I did right now is that I used the Grid feed-in energy as the hourly AC output of the inverters, however the values are much lower than the nominal power of inverters which is unreasonable. Â Quote
developer_mh Posted November 16, 2022 Report Posted November 16, 2022 Dear zhaoyu, the AC output of the inverters can be seen in the diagram editor at the results page. Choose "PV energy (AC) minus standby use" from the list of data series. This data is also available in the csv export file. Hope that helps, kind regards, Martin Quote
