October 31, 20224 yr comment_9106 Hi! I got two pictures where it says MPP 1+2 and don't really understand that. Does Pvsol says that it should be 1 string splitted for the two MPPs because the high Ampere from the panels? The inverter has 2 MPP trackers with maximum 11A. 12,8A from the panels. I don't understand this. Sorry. The Mspaintpicture I made. Is that right? Report
November 2, 20224 yr comment_9122 Hello CHEMASKBG, in case the inverters support interconnection of the MPPs, the input current adds up. Please also refer to the following thread: I put it on our list to further explain it in our online help. Kind regards, Frederik Report
November 2, 20224 yr Author comment_9125 20 minutes ago, developer_fw said: Hello CHEMASKBG, in case the inverters support interconnection of the MPPs, the input current adds up. Please also refer to the following thread: I put it on our list to further explain it in our online help. Kind regards, Frederik Hi. Yes the Inverter supports Interconnection but I don't know what that is. Sorry. It has 2 MPPT with maximum 11A on each. The panels that was calculated gives 12,8A under STC. Pvsol says maximum 22A when it's 1 string. So... I have to use both MPPTs with one string? And it's so easy that I only have to add 2 Y-connections to the string and connect it to the 2 MPPTs? ? Goodwe gw6000-dt 18 panels. Jam54s31/395W Thank you so much for answering. Report
