October 23, 20224 yr comment_9060 Hi, Inverter maximum DC power is not a mandatory design limit parameter for array sizing. The maximum array size that can be connected to an inverter should be determined by the maximum short-circuit DC input current rating and the maximum input voltage rating. Even this is removed from the latest IEC 62894. Can we introduce an option like a checkbox near this data, so that users can disable this from PVSOL calculation? Report
November 14, 20224 yr Author comment_9183 Hi, Are you planning to add this function? Regards, Ajay. Report
November 16, 20224 yr comment_9225 On 10/23/2022 at 9:53 AM, Ajay Deepak said: The maximum array size that can be connected to an inverter should be determined by the maximum short-circuit DC input current rating and the maximum input voltage rating Dear Ajay, this is will be part of the upcoming major release, PV*SOL premium 2023 R1, which will be published around the end of November. Thanks for your input! Kind regards, Martin Report
