Hi,
In the case of multiple MPPT inverters, do we need to add a single MPPT Isc or combined Isc data in the below section?
In most cases of multiple MPPT inverters, I can see combined Isc data. But this is not relevant for inverter protection.
If it is for single MPPT current (Isc), can you add some text mentioning single MPPT Isc in this section?
Hi Frederik,
Thanks for the quick reply.
In addition to this, you may need to add the option to capture the maximum input current per each input terminal.
Future, multiple MPPT inverters will have 4 to 5 inputs. So here limiting factor will be the input terminal (connector) current.
Example: https://support.huawei.com/enterprise/en/doc/EDOC1100191089/8f97422c/technical-data
  • 1 month later...
Hi Frederik,
I am referring to below information, capturing maximum MPP current per String (terminal). I can't find this in the new version.
Regards,
Ajay.
Hi Ajay Deepak
Have you had a look at the latest version 2023 R1? When creating new inverter database entries, it is possible to define up to 3 different characteristics for up to 20 MPP trackers
Is this what you are looking for? Maybe I am just misunderstanding your request.
  • 2 weeks later...
Hi Ajay Deepak,
On 12/22/2022 at 1:13 PM, Ajay Deepak said:
I think there is some misunderstanding
Indeed. For a clearer view into the question it might be helpful to show a small screenshot of the inverter terminal from the Huawei homepage link which you added to your request:
So far, we cannot map this behaviour (a max terminal current limiting the sum of string currents) in PV*SOL, you are correct. There might be cases, in which our configuration check is not able to respect those boundary values.
On 12/20/2022 at 6:18 PM, Ajay Deepak said:
Are you planning to consider this in the development?
We definitely are. At the moment I cannot give a date yet.
