Richard Fotland Posted October 19, 2022 Report Posted October 19, 2022 When I try to draw Parapet wall on flat roof i get a messag that " an attic can only be breaten on building roofs with an inclination smaller than 20" My roof is flat and the button I pressed sat Parapet wall, not attic.. how do I fix this? Quote
Richard Fotland Posted October 19, 2022 Author Report Posted October 19, 2022 1 minute ago, Richard Fotland said: When I try to draw Parapet wall on flat roof i get a messag that " an attic can only be breaten on building roofs with an inclination smaller than 20" My roof is flat and the button I pressed sat Parapet wall, not attic.. how do I fix this? Quote
developer_fw Posted October 21, 2022 Report Posted October 21, 2022 Hello Richard Fotland Unfortunately I cannot reproduce your error. Could you be more specific which steps you did take to get to this message? I did the following: Create a new 3D system with a map section: # Draw a polygon onto the map section: Extrude the object as arbitrary building Right click and activate the building Create Parapet wall I'd like to help but need more information. Kind regards, Frederik Quote
