Hi Muhammad Azhar Bilal
Optically it is not possible to remove one module from your assembly system. In this case you have to create several systems and put them together manually.
Electrically you can select only the modules you want to do use for configuration. In the tab Module Configuration you have to select individual selectability:
After selecting all modules by dragging a mouse selection you can deselect single modules with CTRL+Leftmousebutton. A right click opens the possibilty to Add to Define Module Areas Dialogue:
In besaid dialogue the configuration of the just selected modules is possible:
