Eddie Posted February 9, 2016 Report Posted February 9, 2016 Hello, Â I just purchased the PVSOL Premium and need to design 3 different arrays in one project, is this possible, without setting up three different projects in the software? Â Thanks, Eddie Quote
developer_mh Posted February 10, 2016 Report Posted February 10, 2016 Dear Eddie, Â yes, that can easily be done. Â When not in 3D mode, on the page "PV modules" you see the overview over all arrays on the left. On the top of that tree view there are buttons to create new arrays or copy existing. Here you can set up 3 different arrays (or even more if you want). You can then wire them up on the page "Inverters". Â In 3D, you can just create multiple pv arrays, on roof tops or mounting systems, as you desire. Then you can connect them to inverters using the tab "Module Configuration". Â Hope that helps, Martin Hofmann Quote
