Abdel Rahman Posted August 25, 2022 Report Posted August 25, 2022 Hi, I hope to get support for my problem. I have building with gable roof. I insert picture from map and I drew the building by using sketch 3D polygon option, but the problem PVsol didn't recognize it as gable roof when I used exclude 3D object as shown in the picture . What I can do to solve this problem?      Quote
developer_fw Posted August 26, 2022 Report Posted August 26, 2022 Hi, unfortunately you have to use a rectangle without cantilevers to make this function available. Something like this won't work: A "pure" rectangle with an additional gable line like the following... ...plus a right click opening the context menu entry Extrude 3D Object offers several roofs... ...onto which you can place additional objects like chimneys, dormers and so on: and additional extruded 3D objects next to the building: I hope this does help. Kind regards, Frederik Quote
