August 24, 20224 yr comment_8440 Greetings. I have the problem that I can not adjust the wiring limits regarding the dimensioning factor for Solar Edge systems. The changes in the options is only applied to non Solar Edge inverters. Is this the way it is intended? Is there somewhere an extra option for Solar Edge sizing factors? Report
September 1, 20224 yr comment_8508 Dear sparti117, this is correct, the dimensioning factor for SolarEdge systems is constant and not changeable by the user. This is intended as SolarEdge gives predefined dimensionion factors for their configurations. For 3-phase inverters the maximum dimensioning factor is 150%. For single phase inverters it is 155% for HDwave models and 135% for all other models. Kind regards, Martin Report
