Filip Posted July 19, 2022 Report Posted July 19, 2022 Hello everyone, Â I have run into two problems while designing my solar power system. First one, as you can probably conclude from the title of this mail, has to do with the electricity savings in my results. I thought the savings should get bigger and bigger over the years, but instead I have a constant value of 0.01$. Does anyone has any idea why is that so? And the other question about the currency of the program. I am from Bosnia and Herzegowina and I would want the currency to be BAM, but instead I have dollars. Is there any way I can change it? Â Many thanks in advance. Â Best regards, Â Filip Quote
developer_fw Posted July 20, 2022 Report Posted July 20, 2022 Hi Filip, 18 hours ago, Filip said: Does anyone has any idea why is that so? Try the following: Set the Inflation Rate for Energy Price to 0.0% per year Set the Annual Average return on capital employed to 0.0% Those two factors affect the savings. By setting them to 0.0 you could get a clearer view onto uninfluenced values. 18 hours ago, Filip said: Is there any way I can change it? Yes, but you have to adapt the Region settings in the Windows system settings, which also affects currency. Afterwards you need to restart PV*SOL. Please also refer to this thread: Kind regards, Frederik Quote
