July 4, 20224 yr comment_7840 Hello. I followed the tutorial on importing the 3d model .obj from PIX4D to PV*SOL. When i import from DroneDeploy the model has color but when i import from PIX4D the model has no color. Is there any settings i must change? Any help would be greatly apriciated. Thank you. Report
July 5, 20224 yr comment_7850 Hello Jaka-JB Energy, usually there should not be a problem with the textures. How complex is your model? Does it come with complex (big) texture files? I assume the problem could be the file size. Could you send me the model via private message here in the forum so I can have a look? Kind regards, Frederik Report
October 5, 20224 yr comment_8749 On 7/4/2022 at 1:52 PM, Jaka-JB Energy said: Hello. I followed the tutorial on iporting the 3d model .obj from PIX4D to PV*SOL. When i import from DroneDeploy the model has color but when i import from PIX4D the model has no color. Is there any settings i must change? Any help would be greatly apriciated Thank you. Sorry, to interrupt, but maybe you could share that tutorial. We are searching ways how to import models from Dronedeploy, but we are kind of stuck at this time. Report
October 10, 20224 yr comment_8880 Hello Please Help, I must admit that I do not have a link to such a tutorial by PIX4D. Regarding the import of 3D models it is best to get help from our support: https://valentin-software.com/en/support/technical-support/ Kind regards, Frederik Report
