June 27, 20224 yr comment_7759 hey i am trying to import a 3d object from sketch up but it keeps showing this " there is not a sufficiently large available area on this 3d object" what should i do ? Report
June 27, 20224 yr comment_7768 Hi juhaina, after importing a 3D model you have to draw a mounting surface onto the imported model: Otherwise it will not be possible to place modules: I hope this helps. Best regards, Frederik Report
June 28, 20224 yr Author comment_7773 The problem is the software does not activiate my 3d model , so i can not draw a mounting surface on it… Report
June 28, 20224 yr comment_7775 Hi juhaina, can you send me the model via private message here in the forum so I can have look into it? Thanks in advance and best regards! Frederik Report
June 28, 20224 yr comment_7780 Hi juhaina, via exporting this to .stl, importing it to https://www.blender.org/ and exporting the model as .obj ... it is possible to import your model into PV*SOL and start drawing mounting surfaces: I attached your model as .obj version. Have fun! Best regards, Frederik final_design.obj Report
