Dear support,
I have found a fail parameter in properties of hybrid inverter Solax 15kW G4. Inverter has two MPPTs with two diferent current for one MPPT and second MPPT. He has three inputs for strings in fact. Please doublecheck datasheet and correct it in the software.
Thank you.
Best regards,
Miroslav Sebek
  • 3 months later...
Dear programator,
there is still some issue with number of inputs and current over limits. Please check nominal currents from datasheet. MPPT1 has two inputs for two strings with different current compared to MPPT2.
Thank you.
Miroslav
Hi Miroslav S,
sorry to hear this issue is not closed yet.
Do you have a unique datasheet for the inverter? From the manufacturers website there is no clear information about the inverter which you are looking for. (https://www.solaxpower.com/wp-content/uploads/2021/02/X3-Mic.pdf)
I have asked our database team again to contact the responsible person of the manufacturer.
