Samreen Ameen Posted May 13, 2022 Report Posted May 13, 2022 Hi there, I am facing an issue in PVSol 2021 R5, related to the dimensions taken . The dimension of PVSol differ greatly from the dimension of Google earth, , please find attached a screenshot of both software’s dimensions, another screenshot is attached to make you sure that I put accurate scale of PVSol but the problem still exit. Can Anyone give me a solution for it with little details as i am beginar, please as an urgent bases. Thankyou Quote
developer_fw Posted May 16, 2022 Report Posted May 16, 2022 Hello Samreen Ameen, do you mind trying the following steps? Navigate to the installation directory of PV*SOL (something like "C:\Program Files (x86)\Valentin EnergieSoftware\PVSOL premium 2021\) Look for the executable file PVSOLpremium.exe, right click on it and select Properties Switch to the Compatibility tab and click the button Change high DPI settings Uncheck the checkbox in High DPI scaling override and close all opened setting windows by applying changes if necessary After this PV*SOL might look a bit misaligned (some controls might not be reachable, texts might be cut off or overlapping, etc) but the measured lines in the Map Section tool and the draw-polygon tool in the 3D editor should match. If you have further questions or in case this workaround does not work, please reach out again! Best regards, Frederik Quote
