xueting Posted May 13, 2022 Report Posted May 13, 2022 hello, I choose to record the characteristic curve of the module in the options, but I can only see the string I-V curve of the inverter MPP in the results. Can I see the I-V curve of each PV module? Quote
developer_fw Posted May 17, 2022 Report Posted May 17, 2022 Hi xueting, the characteristics are limited to the inverter MPPs. There is also a limitation when simulating with minute values: In this case you have to choose one MPP. A setting to record characteristics for each PV module is not available. Best regards, Frederik Quote
