sathish Posted May 6, 2022 Report Posted May 6, 2022 i try to import a .dae file. But i cant activate to install the panels on the roof. but the same file can used in other software. the images are below https://wetransfer.com/downloads/c58fbe24053a0c90b433a2712367164820220506120647/86c6e7eada927ba1d1ddfc458451a6f820220506120723/e9b838 1 Quote
sathish Posted May 6, 2022 Author Report Posted May 6, 2022 2 minutes ago, sathish said: i try to import a .dae file. But i cant activate to install the panels on the roof. but the same file can used in other software. the images are below https://wetransfer.com/downloads/c58fbe24053a0c90b433a2712367164820220506120647/86c6e7eada927ba1d1ddfc458451a6f820220506120723/e9b838 the panels are getting installed on the wall instead of roof. Quote
developer_fw Posted May 9, 2022 Report Posted May 9, 2022 Hi sathish, after importing a 3D model one has to define mounting areas onto the surfaces. It should be possible to draw a mounting area on top of the roof area of your building. What steps did you take to place modules? Best regards, Frederik Quote
