April 14, 20224 yr comment_7157 Hi, we would like to know what is the maximum ground mount simulation size in mega watts. We have heard that it is 500 mega watt, is that possible to simulate this size installation? Report
April 19, 20224 yr comment_7177 Dear Davidvc, the only restriction we have in PV*SOL is the number of modules and mounting systems used in the 3D environment. If you plan without 3D, the PV plant size is unlimited. If you plan in 3D, we restrict the maximum module number to 10000 (or 7500 for mounting systems). If you multiply that by the current nominal power of a typical module, say 350 Wp, you get 3.5 MWp as a limit. The threshold is editable in the settings file, though. It really depends on your computer.. Without 3D planning, you can easily simulate more than 500 MWp. Kind regards, Martin Report
April 19, 20224 yr comment_7178 Here is a small screenshot of PV*SOL showing results for a 1 GWp PV system (simulation duration on my computer was < 1 min). Report
