Anna_ Posted March 30, 2022 Report Posted March 30, 2022 Hey, I have a problem with creating an excel file with info about Open circut Voltage. Usually when I create Hourly values I am able to chose a lot data. Now I am facing project where I can choose just: What can be wrong? How can I fix it? Anna Quote
developer_mh Posted March 31, 2022 Report Posted March 31, 2022 Hi Anna, in projects with a lot of module areas, a lot of MPP trackers or a lot of inverters, we need to cut some of the more detailed results due to memory limitations and disk space. I'd guess that the project you are analysing has a lot of module areas? You can set the limit a bit higher, though, at your own risk Close PV*SOL, then open the PVSOL.ini file in a text editor. You can find it here: C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2022\PVSOL.ini Locate the attribute MaxNumberOfModuleAreasForResults and change the value to your liking. You can also play around with MaxNumberOfInvertersForResults and MaxNumberOfMppsForResults. Save the file and start PV*SOL again. Then force a new simulation under Options -> Force simulation. Then the module area results should show up. Kind regards, Martin Quote
