George Tsirivakos Posted March 23, 2022 Report Posted March 23, 2022 Dear support, The current version of PVSOL does not allow me to configure Symo GEN24 5.0 Plus as MPPT1, MPPT2 and 18 SolarWorld Plus SW 290 Mono. It allows only MPPT1+MPPT2 If I increase the modules to 19 then it works. Checking the specs of the inverter and the modules I cannot explain this limitation. Please explain, George Tsirivakos Quote
Jordn Posted April 20, 2022 Report Posted April 20, 2022 If I had this problem, I'd copy and edit the inverter characteristics in the inverter settings, to the desired string makeup known as compatible, check the system configures to all green ticks, then confirm the configuration with the Fronius designer https://creator.fronius.com/ 1 Quote
