CodrinSomesan Posted March 14, 2022 Report Posted March 14, 2022 Dear experts, please note that my version of PVSOL dose not let me to configure the HUAWEY 8 KTL inverter to use 2 strings. Is this happening just to me? How can I solve this problem? IS a software problem? Thank you in advance. Best regards. Quote
Jimmy Posted March 14, 2022 Report Posted March 14, 2022 Hi Codrin,  This is probably because you're using panels that have significantly higher current than SUN2000 - 8 KTL is specified to handle as they have a max input current per MPPT of 11 ampere and your panels probably have 12,5-13 ampere under STC. Huawei really hasn't kept up with the changing times with their inverters. PV*SOL doesn't like this but If you're confident that the solution is fine you can create a copy of the inverter and input higher max amps for the inverter and get a somewhat close approximation to how much energy will be produced (Note that I'm not advocating this and that I'm not associated with PV*SOL). Be careful if/when exceeding the maximum input current per MPPT and make sure that you know what you're doing or you might burn the inverter.  Personally I'd go with other panels or inverter.  Best regards, Jimmy  1 Quote
CodrinSomesan Posted March 14, 2022 Author Report Posted March 14, 2022 Thank you very much, I spoke with HUAWEI directly and it looks that the inverter suports without any problem this current. Thank you again. Best regards Quote
developer_mh Posted March 15, 2022 Report Posted March 15, 2022 Hi Codrin, in addition to what Jimmy wrote, you can set the maximum allowed exceedance of the input current in the configuration limits dialog: Hope that helps, kind regards, Martin 1 Quote
CodrinSomesan Posted March 15, 2022 Author Report Posted March 15, 2022 29 minutes ago, developer_mh said: Hi Codrin, in addition to what Jimmy wrote, you can set the maximum allowed exceedance of the input current in the configuration limits dialog: Hope that helps, kind regards, Martin  Quote
CodrinSomesan Posted March 15, 2022 Author Report Posted March 15, 2022 Thank you very much. Will help me. Best regards. Quote
