TurtlesOG Posted March 8, 2022 Report Posted March 8, 2022 Dear all, Does anyone knows if it is possible to combine multiple arrays of modules into one unique array? Like in the image below? I ask this because PV*Sol sets different amounts of modules on the same area and it's due to the grid it uses as reference. Can I somehow edit this grid? Because it is clear that this space fits 4 vertical arrays but when I fill it automatically PV*Sol set arrays of 4 and 3 because of this grid displacement. Like in the image below! Thank you, any help will be usefull! Quote
Jimmy Posted March 8, 2022 Report Posted March 8, 2022 (edited) Hi Turtles, I wrote a comment but upon rereading your post I realize that I don't understand what you wish to accomplish. It is possible to combine modules into "module areas", but I'm not sure that that's what you're looking for. It is not possible to edit the grid, it is just panel size+distance. If you can explain a little more why you want to do this and what is wrong I think I might be able to help.  Best, Jimmy  Edited March 8, 2022 by Jimmy Misunderstood purpose Quote
TurtlesOG Posted March 8, 2022 Author Report Posted March 8, 2022 8 minutes ago, Jimmy said: Hi Turtles, You can combine any number of panels into a single module area. Â The easiest way to do this is: Â Hello Jimmy! Can you explain the way to do it? Thanks! Quote
Jimmy Posted March 8, 2022 Report Posted March 8, 2022 Hi Turtles, I messed up my first comment and have edited it. Â Here's how you define module areas: Select all panels that you wish to configure together in the "module configuration" tab and the right-click, press "add..."Â Â Quote
Jimmy Posted March 8, 2022 Report Posted March 8, 2022 You can also configure multiple module areas together in the inverter config by ctrl-clicking the module areas and then pressing "configure module areas together" Â Â Then you get this: Â Â You can do that for as many module areas as you like. Â Hope that helps. Quote
TurtlesOG Posted March 8, 2022 Author Report Posted March 8, 2022 Jimmy lets imagine 1 roof only, where I set two different PV arrays. What I want is to combine them to have only 1 PV array instead of 2. So as you can see in the picture I have 2 arrays of 20 modules in the same roof and I wish to combine them to have only one array of 40 modules. Quote
Jimmy Posted March 8, 2022 Report Posted March 8, 2022 Okay, I see what you're trying to do. I'm afraid that I don't think that's possible. And you've tried everything that I can think of. Since this doesn't really effect the inverter configuration I'm assuming that you want to do this because of user interface reasons when designing? Or is it that it shows multiple module areas in the customer presentation? Quote
TurtlesOG Posted March 8, 2022 Author Report Posted March 8, 2022 11 minutes ago, Jimmy said: Okay, I see what you're trying to do. I'm afraid that I don't think that's possible. And you've tried everything that I can think of. Since this doesn't really effect the inverter configuration I'm assuming that you want to do this because of user interface reasons when designing? Or is it that it shows multiple module areas in the customer presentation? User interface reasons! It would be easier to configure the inverters, but it is what it is. Thanks! Quote
developer_mh Posted March 9, 2022 Report Posted March 9, 2022 Hi TurtlesOG, hi Jimmy, it is possible to combine module areas of the same orientation and inclination already in the "Define Module Areas" dialog: Hope that helps, kind regards, Martin 1 Quote
