Hi Sondre207,
I am sorry, I don't really understand what you mean. Do you mean "green line" instead of "blue line"? If you need to place buildings precisely, you can use the position fields in the edit dialog:
If the buildings are rotated, the math becomes a bit more complex. So I'd recommend to create a small wall with the desired distance from the edge, and then place the other house accordingly:
Here, my wall segment is 3.5m wide, because my main building is 15m wide and the rotated building is 8m wide. Once you have placed the second building correctly, you can remove the wall segment.
