Christoffer Jonsson Posted February 7, 2022 Report Posted February 7, 2022 Hi! I am doing a simulation to see the differents between a Amerisolar 370W solar module and for Almaden 310. Amerisolar 370 - 29,23kWp - 24 0000kWh - Perfomance ratio 91,1% Almaden 310 - 26,06kWp - 59 000kWh - Perfomance Ratio 232% Â As you can see there is no possibility that Almaden 310 could generate that amount of power. I have double checked the values to the product sheet and everything looks correct. Do you have any idea on how to troubleshoot this? Quote
developer_mh Posted February 7, 2022 Report Posted February 7, 2022 Hi Christopher, the first thing that strikes me is that in your screenshots the decimal values are left aligned, whereas all numbers should be right aligned. Could you check the inputs again? Did you copy and paste the values perhaps? Perhaps there was some illegal character included that PV*SOL doesn't recognize. Kind regards, Martin Quote
Christoffer Jonsson Posted February 7, 2022 Author Report Posted February 7, 2022 Hi! No i did the numbers manually. It always end up on the left side actually. Dont know why though Quote
developer_mh Posted February 7, 2022 Report Posted February 7, 2022 Hi again, could you send me the project file please? You can send it here in the forum as private message, thanks. Kind regards, Martin Quote
Christoffer Jonsson Posted February 8, 2022 Author Report Posted February 8, 2022 I fixed the problem with the wrong values. But i will send you the project file so you can check on the incorrect format Quote
