Hello there,
Can you have a look at this for me please, I just need to know if I have the panels at the optimum angle as it says no inclination on the report but 30 degree in the set up settings (which is what is needed as is a flat roof).
What do you need to acces my report?
regards
Craig
Hi Craig,
thanks for the project. You have correctly defined the module mounting system with a 30° angle. However you didn't use it on the roof, you placed normal modules without mounting on it. This is why the modules on your roof don't have a tilting angle. You can delete them and cover the roof with your mounting system.
