Usama Alfadel Posted January 27, 2022 Report Posted January 27, 2022 Hi, I am trying to do a simulation for a PV system with an energy storage (BYD batteris) So at first, I started by defining the system, 33 Trina S vertix paneles *395W, divided between two different strings, one with 16 panels and the other is with 17 panels. When I move on and try to define an energy storage system, seems like I can't use the same inverter for the energy storage as the one for the PV system, eventhoug according to the inverter datasheet, the inverter has two different PV inputs, and it has a battery input, so in theorey it should work, but seems like the storage system is a seperate system from the PV system. Eventhough if I change in the database of the inverter and I chose a DC connection methode, it doesnt help. So is it a wrong approach, or is it a limitation in PVsol for the current versions? Please be advised, I tried different versions from 2020, 2021, and the latest version of the program. And what is the idea behind merging the data sheet of the batteries and the inverters ? I mean in the older versions, it was possiable to choose BYD batteries seperatly with their own database, now, the each compitable batteries, comes under the same database of the inverter manufacutre :) Quote
developer_mh Posted January 31, 2022 Report Posted January 31, 2022 Hi Usama, I guess you are already trying to do it the right way. It is just that in PV*SOL, the PV inverter and the battery system is always displayed and configured as two separate devices, even though in reality both could be in the same device. So just choose the same device as PV inverter and battery inverter, and all should be fine. If you have doubts, you can also send me your project file here in the forum, as private message. Hope that helps, kind regards, Martin 1 Quote
Usama Alfadel Posted January 31, 2022 Author Report Posted January 31, 2022 Hi Martin, Thanks for your reply, I have one more question though about what you wrote above: (Just chose the same device as PV inverter and battery inverter ? Do you mean that if I chose the same inverter (ex. Fronius Symo Gen 24 10 plus for my PV system, I should choose the same inverter type and effect for the battery system as well, and a Fronius Gen 24 8 plus won't give me right results in the simulation)? And if the program calculates the two inverters seperatly, doesnt it mean, that in the Financial calculation, we would get 2 x the cost of one of those inverters? And for energy losess in the system, would't it be higher ? Thanks for your help Quote
developer_mh Posted February 7, 2022 Report Posted February 7, 2022 Hi Usama, yes, if you have this one device in reality, say a Fronius Symo Gen 24 10 plus, a combined PV and battery inverter, you should definitely choose the same device twice in PV*SOL, once as a PV inverter, once as battery inverter. In the financial calculation you only enter the price of the one device. The energy losses are not higher, since both the PV inverter losses as well as the battery inverter losses happen in a real device as well. Hope that helps, kind regards, Martin Quote
Usama Alfadel Posted February 13, 2022 Author Report Posted February 13, 2022 Thanks for the explination Martin, Quote
