January 21, 20224 yr comment_6637 Bom dia, Estou importando um modelo 3D .obj para o PV Sol mas ele sempre esta carregando o modelo de lado, como eu poderia rotacionar este modelo para que fique paralelo ao plano horizontal? Segue imagem do modelo importado. Report
January 21, 20224 yr comment_6638 Hi Larissa, It's best to ask the questions in English, but I think I can understand you're question. If you right click the model and choose edit you can set it for "Tilt backwards" Than it should be in the correct alignment. Greetz Johan Report
January 24, 20224 yr comment_6648 Hi Larissa, I'll have deepl translate your question for everybody in the forum: Quote Good morning, I am importing a 3D model .obj for PV Sol but it is always loading the model sideways, how could I rotate this model so that it is parallel to the horizontal plane? Here is an image of the imported model. The option that Jimmy showed is the right one. I can't really get your first image and the rotated images together, do they come from the same imported model? If really there is no way for you to import you model correctly into PV*SOL, try to rotate it in Blender first. Kind regards, Martin Report
January 24, 20224 yr comment_6656 Larissa, você pode entrar em contato comigo - somos os responsáveis pelo suporte em portugues: suporte@solarize.com.br No seu modelo 3D há várias partes desconexas. Sugiro limpar o modelo antes de exportá-lo. In English: I´d suggest to clean the 3D model before exporting it - there are several parts without connection to the building. Report
November 16, 20224 yr comment_9201 Eu uso o Blender e é muito bom. mais programas de Modelagem 3D: https://www.xp-pen.pt/forum-6151.html Report
