I allocated two inverters to models in zoom 1 & 2 according to the number of modules in 2 zooms. (The software itself allocates two rows together) And strings are as pictures show us in different colors. But I want to allocate inverter to module row array independently. Invert NO.1 is used for modules in zoom 1 and the other is for zoom 2.They are in chaos now. I've changed the direction and starting point, but it's useless.
Can I achieve what I have expressed?
Hi Venco Gary,
firstly I would recommend to delete the configuration that you have in order to start from the beginning. Then, in the module configuration tab, select the modules in area 1, right click and select "Add to 'Define Module Areas' Dialog":
Then go to the "Define Module Areas" dialog and select "Configure"
Like so you have configured the modules in area 1. You can proceed in the same way for area 2.
