Problems with adding consumption data
Hi,
I have problems when adding consumption data. I add in 12,9% for february and 12,67% for march and everything looks ok. But it still looks like consumption is higher in march. Any tips for what I should be checking?
Dear Sondre207,
the percentage value that you enter and see displayed on the input dialog (bottom section of your screenshot) is the mean or average daily consumption in %. The consumption in kWh per month that you see in the upper diagram is the mean daily consumption multiplied by the number of days per month and then multiplied by the annual energy requirement. This is why February with its 28 days is lower than March with 31 days in the upper diagram whereas it appears higher in the lower diagram.
