November 5, 20215 yr comment_6216 How to set it if we can do? What I know is to set the average price per kWh or set different price according to range of consumption. Valley(0:00-8:00) ; Peak(8:00-12:00,17:00-21:00);Mean(12:00-17:00;21:00-24:00) Report
November 5, 20215 yr comment_6218 Hi Venco Gary, you can use tarriff zones when defining an from-grid tarriff, like so (never mind the € sign, the currency symbol is taken from the system): In the right side of the dialog, starting frm the top, you can set the number of zones to 3, then enter the prices for each zone (1.0207, 0.5968 and 0.2529), and then, in the tarriff zone table at the bottom, just highlight the cells you want to change and type in the number of the zone. I didn't know what the last two rows (daytime and average) where referring to, so I didn't include them in the example. Hope that helps, kind regards, Martin Report
November 5, 20215 yr Author comment_6220 Thank you for your kind support. And how to change the currency symbol? Report
November 5, 20215 yr comment_6221 Hi, since PV*SOL is using the currency symbol of Windows, follow these instructions to change it in the Windows settings: https://www.isunshare.com/windows-10/customize-currency-format-on-windows-10.html Kind regards, Martin Report
