How do I change which edge of a sketched mounting surface an array is oriented after?
This picture might easily explain what I want to do.
I can't find the option (if there is one), like there is with regular buildings which have predetermined edges. And I can't figure out how PV*SOL determines which edge to orient after since I've tried reversing the order that I draw it in to try to find a work-around.
Hi Jimmy,
if you use module mounting systems, you can select the edge that is used as a reference:
The module coverage tool doesn't have this option. If you need the modules to be mounted horizontally, just set the mounting angle to 0°.
