problems with defining location and importing measured climate data
Hello,
I am trying to upload a climate dat-file. First I try to define a new location, but PV SOL seems only to allow me to use a database from Meteosyn. When a location is created, I am able to go to the import data-section. PV SOL then seems to be importing the data. In most cases the imported data does not seem to overwrite the climate data from Meteosyn at that location. The program also does not allow me to create my own location with imported data only. In some cases I was able to update the climate data, but then I got the error messages that it was not aligned with Clear Sky Data. I have been trying to shift the data 1 hour each direction, but no success.
I have read earlier topics on this forum, but was so far unable to find a solution.
Best regards & many thanks in advance!
Hi Rotterdam and welcome to our forum,
could you send me the .dat-file via private message here in the forum so I can have a look why this does not work?
Which version of PV*SOL are you working with?
Best regards,
